couple little questions
    I did some searching, but i didn't really find what I was looking for to answer my questions.
    My tach, odometer and mpg gauge don't work. From reading it'll be the "si board" Is this correct? Would it be easier just to swap the cluster?
    The onboard computer doesn't work. Is it probably the unit, or wiring?
    When the car is running it idles fine, but when I rev/drive it, when I come of the gas, it doesn't just come down, it kind of hangs and revs for a couple second then comes back down. Is this a common problem?
    check the fuses yet?
    Swanny!
    SUCKERS.
      Ya, but I can check again. Is the OBC and the tach/econometer/odometer all ran on 1 fuse?
        i'm pretty sure the tach/mpg/odometer are... fuse 10
        Swanny!
        SUCKERS.
          Ended up being a bad fuse 21. Now the cluster and OBC is working, but the OBC is reading in KM and Celcuis.
            hit the small set pin with a ball point pen and then the mpg button. that should change it us settings.
              OK, i'll do that in the morning. Thank you.
