hesitation/bogging at 3500 rpm
  • tunethtmkII
    • Apr 2011
    • 297
    When I first started driving the car it had this problem. If I got on it in the lower gears it would hesitate and bog at 3500 rpm until 4-4500 rpm then it would continue to pull strong. After awhile it went away until recently. But now it seems to do it only after put some gas in the tank. About 1 out of 20 times the car will have a starting issue and has to crank for awhile before starting. And now its starting to hiccup right when its started. Not sure if these are connected or not. I believe it may be a bad coil. But I was just curious for others insight.
    The car is a 325i with a b25. And injector o rings were just replaced not too ling ago. And its reading a o2 sensor Cel.
    Tuck tire. Poke rim.
