I have a 1992 e30 325ic. Im a newbie
I decided to upgrade the injectors and put in at mark d chip. I took off the intake manifold,airbox, and throttle-body To put in new injectors and removed the ecu and put in the chip. I put everything back in exact order and started the engine and nothing. It turned over but it doesn't seem to fire.
And it seems the hose to the fuel rail are not getting gas.. Does that have to do with anything?
Things i tried
-I tried to get the fauilt codes by pressing on the gas five time and no codes came up
-tapping the starter
-waited a few days to start again.
-replace the fuel pump relay
Is there a way to test the ecu if i put it in right? if thats the problem
Any tip or suggestions would be great!
Things i tried
