Where is the brake light relay?
  • BENdashdash
    Tom is not my friend
    • Aug 2004
    • 2506
    The brake light warning has been lighting up my check panel ever since I got the car. I've tried replacing the panel. Right now, my complete interior is out and I'd like to locate the break light relay to try and fix this issue. Where is it? I hear its in the back but I have yet to find it. I have a cabrio but any input would be helpful. Thanks.
  • AdamF 88iS
    • 2051
    It's in the trunk, up in front of the antenna motor; but I'd put a new brake light swtich on the pedal before I messed with it.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • BENdashdash
      • Aug 2004
      • 2506
      My brake lights work though
      • AdamF 88iS
        • 2051
        Yea, I know. Put a new swtich in.
        Adam Fogg- '88 M3
        • BENdashdash
          • Aug 2004
          • 2506
          Thanks, I'll try that. But what is your reasoning for the switch? Corrosion?
          • m42technic
            • 1056
            Ive had brake switches switches crap out on me on both of my cars, I have to agree with Adam.
            James Peacock
            WWFSMD?
            • AdamF 88iS
              • 2051
              They just go bad internally, bad soldering or something. They updated the design now though.
              Adam Fogg- '88 M3
              • BENdashdash
                • Aug 2004
                • 2506
                Whelp, I replaced the switch yesterday. The check panel light still won't go away. Ideas?
                • AdamF 88iS
                  • 2051
                  Do any of the brake light bulbs have brass bases?
                  Are all of your grounds good? Clean connections?
                  The relay box is in the trunk on the left side, in front of where the power antenna is if you want to swap with a different one.
                  And you do know that the brake light warning always comes up every time you start the car and should clear itself after you press the pedal?
                  Adam Fogg- '88 M3
