Ghost door locks? - 89 325is
  • sector6
    • 909
    Strange thing happened the other day with my door locks. Maybe some can shed some light...
    I drive to work, park, leave my keys in the ignition, and go inside. The car is unlocked w/ the windows up. I come out at lunch and find all my doors locked as well as the trunk and the keys are in the ignition. Sweet, I only have one set of keys (AAA to the rescue).
    Question is, how can the doors and trunk lock without using the key on the outside of the door? Everything was locked and the keys were still in the ignition.
    I did some experimenting afterwards - long story short, I determined that the only way seems to be to lock the doors from the outside with the keys - end of story. That being said, how can everything get locked while the keys are still in the ignition? Perhaps I'm missing something? TIA
  • JTDay
    • Dec 2009
    • 521
    Sounds like the opposite problem I have had. Sometimes I will lock my car, only to come back and find that it has unlocked itself. Its only done that a few times. G/l with your issue...
    Past: 1987 325iS, Bilsteins - HR Sports
    Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
    2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
    • ScHpAnKy
      • 1573
      check to make sure your driver lock isn't binding, mine was in the iX and it causes the doors to lock and then a few minutes later unlock
      91 318i | 87 535iS
