a dumb thermostat question
  • BavBeater85
    • Mar 2012
    • 143
    on the later model e30s where the cooling system is reversed does thermostat still go in spring towards head? I left mine out cuz when I put it in that way i couldnt get the air out of the system....even tried lifting the front and dumping coolant straight into the radiator and bleeding it while off the ground
    may you rest in peace, or pieces, whichever comes first
    Yes the thermostat goes in the same way on early and late model cooling systems. Bleeding is easier if you drill a 1/8-3/16" hole in the thermostat plate and orient the stat with that hole up. Bleeding one of these engines isn't that difficult, but you have to do it the right way:
    1) Using ramps or a jack get the front of the car 1' or more higher than
    the rear. That will make the radiator and bleed screw the highest point
    on the engine and facilitate removal of air.
    2) With the bleed screw open, add coolant until no more air comes out of
    the bleed.
    3) Leave the filler cap off, or at least loose, and set the heat for max
    temp and fan speed. Leaving the cap loose will prevent air that's still
    in the system from causing a "coolant fountain" once the engine heats
    up. Start the engine and allow it to warm up to operating temp. As it
    warms up occasionally crack the bleed screw to release any air and top
    up the coolant as necessary.
    4) Once the engine is at temp bring it up to 2000-2500rpm for a few seconds
    several times. Then crack the bleed until no more air is released. At
    this point the heater should be throwing lots of hot air, which
    indicates that the heater core is filled with coolant. You may have to
    repeat this a few times to get all the air out.
    5) Drive the car a bit, allow it to cool back down, and recheck the
    bleed for air. Over the next few days you may get very small amounts (a
    few bubbles) of air out of the bleed screw.
    • BavBeater85
      • Mar 2012
      • 143
      ok, that breaks it down into steps better...thanks....I think the lack of thermostat may be whats makin the car run so rich, seein as how its always cold
