My M3's engine temp gauge has not worked since before I bought it. I think the previous owner messed up the wiring because there was about 5lbs of crap connectors for the sound and alarm system that I took out of the footwell alone! Anyway, I didn't care much while the s14 was in there but I have now done an s38 swap and need to more carefully monitor the temp since it generates MUCH more heat and my cooling system is custom.
When the key is turned to Pos II, the temp needle nudges from rest to very cold then never does anything else regardless of how long the engine has been running. It does not jump around, and I have never seen it above cold with either engine in it. I have put in new temp sensors on the coolant rail and it did nothing. Yes, I get heat threw my heater, so its bled correctly.
I just tried another e30 M3 cluster as well as a '89 iX cluster and neither registered any temp gauge reading, same story every time.
SO... there must be a breakdown elsewhere. I'm hoping there is a loose ground nut or something but can't find one.
Could any of the following disconnected plugs be related? There are five. three in my hand, the white plastic square in the middle with two prongs and the bright orange. None of those are plugged in and I don't know what they are suppose to connect to since I can't find 'mates' for them.
This one is for the 13 button OBC correct?:
