leaky mater cylinder at the plugs
  • el_4ever
    • 145
    i have a pretty aggressive leak comming from right in between the brake fluid res. and the plugs that go right in to the brake master cylinder...can i just replace the plugs to stop this or should the entire unit be changed...as long as there is fluid in the expansion tank the pedel feel is good.
  • AdamF 88iS
    • 2051
    You can just change those little plugs.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
