I have an ‘87 325is, and there is no heat coming out of the vents.
I have a friend that is pretty good with cars (well a lot better than me) and we looked at it today. We sourced that the water running through the reservoir to the radiator and out to the thermostat is hot but after it leaves the thermostat it is cold. The thermostat gets hot like it should but everything from that point on is cold. We checked all the temperature levers and they are pushing and pulling, opening and closing. We checked the heater core and the pipes leading into it and they were cold. So I don’t think it is the heater core due to nothing hot even getting to it.
Oh and we check the valve in between the thermostat and the heater core, we unhooked it and ran it under cold and hot water to see if it was opening/closing and it checked out. Is there something between the thermostat and the heater core that I am missing?
I thank you for your help in advance.
JIM
JIM
