AC, Low beams, Blower motor, fog lights
  • barry
    • 1642
    OK guy's need help with the above not working.
    AC does not kick in, blower motor does not turn on, could be the resistor, does not operate at all om any speed. Low beams do not come on? Fog lights do not come on. High beams work great.
    Fuses seem to check out fine, car starts fine, Can the relays support this problem?
    Thanks for your help
    Barry
    I can't think of any single thing that would cause all of those failures, so I suspect multiple independent problems. For the lights, the first thing I'd suspect would be the headlight switch followed by the lighting relays. AC could be a bad switch, low refrigerant, relay, etc. The blower could be a bad switch or bad blower motor.
    • barry
      • 1642
      reply
      Hey Jean my thinking also on all the above, blower is original resister is probably shot, AC switch is original also, lights I think that is a relay problem, high beams work well, all fuses are working so switches and relay's seem to be the culprits
      Thanks again for your help
      Barry
      • Cyrix2k
        • 593
        if the blower doesn't work on the highest setting, then it's something other than the resistor board. If it's like mine, the blower is seized and will blow fuses like no tomorrow.
        1997 540i/6 - stock
        1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
        1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
        • barry
          • 1642
          OK guy's I found the problem, There is a small wire that goes to the starter that was not hooked up now everything works.
          Thanks for all your help
          Barry
