Jordan, somebody, help!
  • cowden_12
    • 354
    Well my car is still running bad. I will be driving along like normal and sometimes when i hit a bump it seems that all of a sudden my car will lose all but a little bit of power. Cant get the engine to rev up at all. Youll find many other post on this on here. Everytime i think ive figured it out it does it again. Comes and goes for about 2 to 3 months now. This is what ive replaced.
    TPS
    Plugs
    wires
    Fuel P R
    Filter
    fuel pumps
    Relay
    Coil
    Cap
    Rotor
    Any other ideas? Thanks
  • Jordan
    • 12916
    Electrical.
    Likely a lose connection.
    Can't help you any more then that without having the car in my hands.
    https://mtechniqueabs.com/
    • AdamF 88iS
      • 2051
      Which relay did you change? There's more than one that can do that.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • cowden_12
        • 354
        Replaced Fuel Relay
        • AdamF 88iS
          • 2051
          Try the Main relay next. It's right next to the fuel relay, sits down a little lower.
          Adam Fogg- '88 M3
          • cowden_12
            • 354
            ok, could it be the alternator too? just remembered the other day the battery light came on for a short time. Could this explain why when i hit a bump it hesitats?
            • george graves
              • 20003
              Clean your battery terminals to start with...
              Originally posted by Matt-B
              • BahnE30
                • 1050
                check your trunk ground cable, mine vibrated loose, and the car died, poped hood, slammed door fiddled with fused jumped back in turns out slamming the door was making the cable make contact again..... tightnd the cable down never had a problem since......
                • golde30
                  • 11464
                  same for me.
                  IG: @Baye30
                  • cowden_12
                    • 354
                    Where is the trunk ground cable at?
                    • Jordan325iC
                      • Aug 2005
                      • 1697
                      I'm here! Don't panic! What's your problem?
                      '88 325is
                      VP UT of Austin Autoholics
                      BMWCCA 380364
                      • cowden_12
                        • 354
                        • Jordan
                          • 12916
                          Right next to/behind the battery.
                          • cowden_12
                            • 354
                            Sorry mines a 84 318. Batteries in engine bay. Is it the one by the strut?
                            Just makin sure theres no two.
