Turn signal problem!
  • bimma360
    • 1940
    So my right turn signal is being kinda screwy. It blinks really fast which means that something is not right. I checked the rear signal and it works fine. Then i figured that it might be my front bulb or something. And as i suspected it does not blink. HOWEVER, when i have the parking lights on the bulb itself is working but when i use the turn signal it does not blink. Am i missing something?
    E30 Dinan Turbo
  • James Crivellone
    Head Janitor
    • 6305
    the bulbs are dual filament, one of your filaments is blown.
    just replace the bulb, and while ur down there, clean the contacts as well :)
    • bimma360
      • 1940
      SWEET..... Thanks!
      E30 Dinan Turbo
      • kencopperwheat
        King of Kegstands
        • 14396
        Also make sure that they're plugged in all the way behind the housing.... that was my problem.
        Originally posted by Gruelius
        • darien28
          • Jan 2004
          • 240
          the housings are really old, and I'm guessing the metal spring-like contacts are pushed pretty far back.
          what I had to do was get a small screwdriver and pry the little things out so that it would stick out more and make better contact. you might want to do that as well.
