Tonight I drove out to get some food. Temperature is 30 degrees. The car was cold to start but once it warmed up I was getting good heat through the vents. I had to stop at a stop light and wait for a couple minutes and at idle I got VERY little heat. If revved up, it would start putting out good heat again, and then when back to idle, it would get colder again. Also, when turned back to cold the air got very cold, so it had little heat but it still felt cold to the touch. Could it be the thermostat stuck mostly closed? The waterpump was changed with the timing belt about 15k miles ago so I wouldnt think it would be the water pump. Also lately with the temps around 60 degrees at idle for a couple minutes the temp would start to climb PAST the halfway mark when before it would go to about 1/2 and then stay there. Any ideers?
Will
Will
