Blower motor making funny noise
  • lolcantturn
    • 4588
    It sounds like there's paper stuck in it or something...is it on it's way out?
    Originally posted by TSI
    OEM+
  • Kvasi
    • Apr 2011
    • 1122
    Outer "bearings" are worn out and they cant be changed, that sound is the shaft having to mutch room and rattles. Buy a new blower, only takes 0,5 hour to get it changed.
    • lolcantturn
      • 4588
      Fair enough, thank you :)
      OEM+
      • jw 325ic
        • Sep 2006
        • 1360
        Lolcantsearch. Just replace it...
        • lolcantturn
          • 4588
          Lolcantfunny . Don't know what a broken blower motor does, it blows well and the dash doesn't vibrate, thought it could be a disturbance somewhere.
          OEM+
          • Kvasi
            • Apr 2011
            • 1122
            It will get worse, ive been there..
            There is btw two different fans as ive found out. If the housing is made from plastic (as mine late model w/o ac) its the smallest one, and if its made from metal its the biggest.
            Theres around 5cm difference between them in overall length.
