Started parting my car when all of a sudden (dunno what happened), lost all power (probably when I ripped the aftermarket alarm out). Continued parting my car so my interior is basically bare now, but my passenger door won't open now and I want to take it off. Any clue on how to unlock this? I tried using the key from the outside, central locking is dead, tried pulling it up with my hands, no budge.
Door won't unlock
Tags: None
if u get the door panel off with the door shut you could undo it from inside the lock cylinder is only held in by 1 clip you can pull off with a flatheadShawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
2971a Roundtop Rd, Middletown PA 17057
bimmerbuddiesllc@gmail.comComment
Is the door card off? If so you should be able to set the actuator free by removing the two 6mm screws.#30 Overengineer'd Racing - Wilton, NH
We need friendsComment
Its double locked so the key wont do it and you cant pull it up...BUT try turning the key a bit while opening the door, i noticed my double locking mechanism was a bit worn so though the key wont turn the lock it turns just enough to (if you pull the door handle while turning the key) you can open the door.Comment
