M30B35 swap, runs rich..help
  • hammertime
    • Jul 2012
    • 55
    I just purchased a swapped e30 with an m30b35 swap from a 91 5 series. The car seems to run a bit rich, has a brand new o2 in it. Any advice as what to check, or are there any diagrams for the wiring? I figured it has to be something not wired in incorrectly. Still has the m20 harness.
  • kronus
    • Apr 2008
    • 13028
    if it's running rich it will quickly foul 02 sensors. Can we have some details on the swap? Modifications to the engine? By the way it's an M30B35 ;)
    Check out Frank M's swap writeup in the M30 subsection, it has a lot of wiring details.
    cars beep boop
      A 91 E34 5 series could have had an M50 2.5L or an M30 3.5L engine. It the car has an M20 harness, the M30B35 is more likely. But then, with the M20 harness, if that is really what is there the engine could be an M20B25.
      • hammertime
        • Jul 2012
        • 55
        Sorry guys, it was an m30b35. The swap looks clean. No modifications. Although he did weld up a full 2.5" exhaust, cat deleted. It just backfires alot, idles kind of rough.
        • 603Racing
          • Dec 2010
          • 612
          Check the M30 swap write ups mentioned and verify all necessary parts have been swapped accordingly. Sound like maybe something electronic related to air/fuel delivery is not correct or maybe not working properly... MAF? ECU? Injectors? TPS?
          How does it run at WOT? Not sure about the M30b35 MAF, but my older M30b34 MAF (euro '83 model) has an adjustable flapper.
          90 325i DD/Track
          03 Durango 5.9
          Originally posted by e30mpg
          It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
