Fuse problem
    Fuse problem
    Hi Guy's
    I have several fuses that do not seem to work, #3, #7, #11, #18, #29, #30
    I have cleaned all the contacts in the fuse box, I'm wondering if a relay may be responsible.
    Thanks
    All of the fuses mentioned have relay between the fuse and power. So you won't see power at the fuse unless the relay is activated.
      Hey Jean I figured it out but thanks again for your input
