Green Tag means what fluid?
  • nefarious7907
    • Jan 2005
    • 1170
    My tranny had, the green fluid tag on it. But I am still debating using dealership stuff or redline but I am not sure which if its comparable to MTL or MTL 90?
    http://www.cardomain.com/ride/657387
  • Eurospec
    • 2613
    This link should be of some help.
    http://tinyurl.com/dzkbj
    • nickmp0wer
      • 1427
      are there any disadvantages to over filling it?
      • Old'n'Slow
        • 436
        There's no benefit to overfilling. However, it is possible that leaks will occur if the oil level is above the seals. Also make sure your breather valve at the top of the tranny moves freely and isn't gunked up.
        I've heard, contrary to link above, that regardless of the label, put MTL, not MT-90 in it. I have a red label, and even though ATF D4 is recommended for easiest cold shifting, the MTL is a better match for the aging syncros that benefit from the friction modifiers in MTL.
        Oil choice is always a slippery (pardon the pun) topic. Everybody has an anecdote of what works best...
        Honestly, for daily drivers I don't think what's IN the gearbox is as important as good shift habits, i.e. gentle upshifts and rev-matched downshifts, never slamming the shifter, etc., for gearbox longevity.
        • nefarious7907
          • Jan 2005
          • 1170
          Thanks for the info, I think that changing my 200k diff and tranny fluids should make a welcome difference.
