Ok, so recently my check engine light has been sporadically flickering. It will never stay on for more than 2 minutes max. It will blick on and off like a loose wire or something. At 1 point, i thought it was rev-related, because if as i revved higher it would blink on and off. Then tonight, on my way home in the rain, it came on and the wipers went to full speed, even when i had them on intermitant or even if i just tapped down once. The whole time this happened the check engine light was on, and as soon went off the wipers returned to normal. 2 minutes later, it came on again, and the headlights suddenly got brighter. Not high beam bright, but brighter than usual. Light went off and brightness went back to normal.
What the fuck is going on?
