Fuel Line Lengths
  • AdamPlaysDrums
    • Apr 2012
    • 140
    Fuel Line Lengths
    I have a 1991 318i. The fuel line leading from the tank to the fuel filter is badly cracked, as I discovered this morning. It appears that I'm going to have to drop the fuel tank to replace this, so I thought I should go ahead and replace some other lines as well. Does anyone have a rough idea as to about how much fuel line I should purchase to replace ALL of them? I may not do it all at once, but it would be nice to know.
    Thanks,
    -Adam
  • dnguyen1963
    • Nov 2011
    • 2651
    I bought 5 m from Blunttech and that was enough to replace all the lines.
    • SmokeE30
      • 1730
      also reloem gives the lengths of each individual line in mm when you look them up
      Shawn @ Bimmerbuddies
      Bimmerbuddies LLC
      717-388-1256
      2971a Roundtop Rd, Middletown PA 17057
      bimmerbuddiesllc@gmail.com
        You should be able to replace that piece of hose w/o dropping the tank. That hose connects to a hard line that runs over the top of the tank.
        • AdamPlaysDrums
          • Apr 2012
          • 140
          Awesome, thanks everyone.
          Jim, I thought that would be the case but I can't get ahold of that part of the hose, it's too far in.
          Also, in order to replace all the fuel hoses would I need to drop the tank? I would assume so but I have heard otherwise...
            I've changed all the hoses before without dropping the tank. Some of them are a bit awkward, but it can be done.
            • AdamPlaysDrums
              • Apr 2012
              • 140
              Brilliant. Thanks again for the info everyone.
