No reverse lights
  • FAs
    • Jun 2011
    • 95
    No reverse lights
    I changed that large rubber shifting stopper or seal a while back. Apparently, I cut the wire for the reverse lights. now I can't find it under the car on the transmission. Can I just use any gage wire to reconnect the transmission and have reverse lights work again?
    FAs
    • 37832
    Why the hell would you CUT the wiring?
    Sure you can wire it yourself. Or just post a WTB thread for a good reverse light harness.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • SmokeE30
      • 1730
      its just two wires with spade connectors on the end, the only two wires coming off the passenger side of you tranny if you cant see em they may have fell off but they are easy enough to make or buy
      Shawn @ Bimmerbuddies
      Bimmerbuddies LLC
      717-388-1256
      2971a Roundtop Rd, Middletown PA 17057
      bimmerbuddiesllc@gmail.com
      • bmwguy325is
        • May 2011
        • 1263
        Ya i am with this. What part of a boot replace requires cutting of wires?
        Im not sure if I recommend you work on your car any further. Next post will be "I changed my oil and it appears I cut the entire harness off the ECU can you guys give me the pin numbers?"
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        • FAs
          • Jun 2011
          • 95
          Sure. sure little man. I say little man because you know I'd smack the sh@t out of you in person "mr badass behind a computer screen"
          FAs
          • blackhawkimpact
            • 2415
            Temper temper.
            • JinormusJ
              • 6887
              Ahhhh r3v...
              :rofl:
              • b*saint
                • 3794
                I was under the assumption he accidentally cut the wires.
                Ma che cazzo state dicendo? :|
                • HippyEarly
                  • Jan 2010
                  • 320
                  I would like to assume the you just pulled the spades off their connectors. Just plug them back in. If you did nip'n'slit use wire that at least the same size. O and carry a fire exstingusher. If you do it wrong that shit might catch on fire. There are fuel lines down there.
                  Been with me for 16 years...
                  Wish i had more time to play with her
                  • SmokeE30
                    • 1730
                    fuel lines dont run down the trans tunnel..
                    Bimmerbuddies LLC
                    717-388-1256
                    • FAs
                      • Jun 2011
                      • 95
                      Please describe this fabrication you speak of...
                      How would I connect the wire to transmission reverse light switch,
                      FAs
                      • bmwguy325is
                        • May 2011
                        • 1263
                        FAs
                        Id tell you the same thing to your face gladly. Im not some keyboard hero.
                        • Rsully70sev
                          • 2391
                          Originally posted by blackhawkimpact
                          Temper temper.
                          This is r3v. You're going to be ridiculed for doing stupid shit, or what we interpret as stupid shit. Chill out, accidents happen- you could have snipped something much worse on accident, this is minuscule.
                          ...I bought my car without the reverse lights working 8 months ago, doesn't bother me in the least bit, I haven't even attempted to source the problem. I just use my brake lights if I NEED a little extra light (parallel parking mostly)...
                          • blackhawkimpact
                            • 2415
                            Why you quote me? I kill you!
