Hey guys, i have a 1987 325 is it has a few things done, (Cold air intake, Exhaust) i was wandering if there is any cheap mods, that will give it some perfomance. Thanks guys!
Performance Help?
Performance Help?
sigpicInstagram: bir_madhatter
Add me on Facebook: https://www.facebook.com/connor.mcco...57?ref=tn_tnmnTags: None
What cold air intake are you running?sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
When i got the car it had a crap ebay intake, i havent had the chance to change it, it doesn't seven have a heat sheild, its basically just a hose to a cone filter, and the exhaust i got with it is a fart can lol, i plan on changing that as well.sigpicInstagram: bir_madhatter
Your best bet with the stock AFM is to run the stock air box with a good filter and make sure you get the velocity stack in there.
As for exhaust long tube headers and 2.5 single.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
i have a small list, of stuff that cost under 1000 bones each, (let me knwo if these are good ideas)
-Legit Cold air intake
-Headers to a borla muffler, deleted cat
-Polished, ported head
-Polished ported intake manifold.
-Engine chip
-Cam.
I will not be doing all of these at the same time, lol it will be a long process.sigpicInstagram: bir_madhatter
