all m20 blocks created equal?
  • ColdAccord
    • 5926
    just wondering if the m20b25 and b27 had the same block. i thought so, but someone who enquired about it thought different
    i was under the impression that only the ix block was different
    Originally posted by blunt
  • StereoInstaller1
    GAS
    • 22679
    Damn, somebody who knows something speak up!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • Jordan
      • 12913
      Yes. For all intents the early b25 and b27 block are the same.
      Late b25 blocks used different main bearings. (I have a late b25 block in my car)
      I don't know about the b20 and b23 blocks.
      https://mtechniqueabs.com/
        • 37829
        Yup, only difference in those 2 was the main bearing change
        I have an early style b25 block in my car
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Borat
          • Jan 2005
          • 494
          Lots of different M20 blocks around. The B20 and B23 blocks only have a 80mm bore size, they also lack the steam holes between the cylinders which aid cooling, good but not necessary. There is also a difference with some of the 5 series blocks- the dipstick goes through the oil pan, not through the block. This wont be a big deal for the US guys but we didn't get E30 etas over here so we have to use 5 series M20B27. Then there are changes like the main bearings...
          Can't comment on iX block though
          • AdamF 88iS
            • 2051
            The IX block just has the dipstick in a different spot.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • ColdAccord
              • 5926
              which would have to be filled and drilled if going into a rwd car cause of the different oil pan
              • Madhatter
                • Oct 2004
                • 966
                B20 and B23 blocks are different as above, they have much smaller bore sizes for starters, they also use the distributor location on the side of the block (so they have a shaft from the oil pump for the distributor).
                Just a little project im working on
                - http://www.lse30.com -
                • Borat
                  • Jan 2005
                  • 494
                  um sort of, ALL blocks (that i have seen-E30/E34) have the shaft for the distributor, only there is a plug over the hole for cars that use the head mounted dizzy. Whether they have the dizzy on the side of the block or head comes down to whether they are L-jet or moronic, so the only difference I know of is the steam holes and bore size as I mentioned ealier.
