I've had and E30 M3 for about 5 years now, and I just picked up a '91 318is today. I drove it home about 450 miles and found out I have a problem with the heat in the car. No matter where the thermostat switch is set the blower only blows very hot air, like it's turned all the way hot. If it's turned all the way cold, it will blow cold air, but if it's only 2mm away from all cold it blows hot as hell.
Any ideas?
also, the temp. gauge reads between 1/2 and 3/4 mark the whole time. Never gets any hotter though and never over heats. I only know the S14 motor, this is my first run in with the M42, and I've never experienced the interior temp switch issue I'm having. Any help is appreciated.
Thanks
Dave
'90 M3
'91 318is
Any ideas?
Thanks
Dave
'90 M3
'91 318is
