running hot when driving
Follow Up
Following up to close the thread.
I felt the radiator and expansion tank & cap were ok so I drained the coolant and just replaced all the hoses and the thermostat (80 degree). I filled with "Bar's 10 minute flush" and water - it's all they had other than a similar Prestone product. Neither of these was an acid flush. The car immediately ran cooler, between the first and middle tick mark.
I think it was probably just a stuck thermostat or one that didn't open all the way. I say this because there really wasn't much gunk that came out when I drained or flushed. This could have been the lack of a decent chemical but I think the system was pretty clean to begin with and the restricted flow caused the issue.
I flushed thoroughly and filled with distilled water and antifreeze, bled, and it's now running as it used to. Takes a while to warm up but never comes close to reaching the 12 o'clock tick mark.
Not sure if this fixed my poor heat but I had good flow through the core (disconnected these hoses and flushed with water) and both in & out hoses got nice and hot when running. Heater put out hot air but it's also warm out.
In the end it was an easy fix but I appreciate the help everyone. Thanks.1985 325e ddComment
