Help - Fuse Box (E30)
  • jackyl
    • Sep 2005
    • 76
    Hi, can anyone give the position and what it means, of each fuse, and the relay(i hope this is the correct word for it) of the E30?
    And even better the amperage of each fuse.
    I suddenly lost the electric window (driver side), and the electric mirror.
    Thanks
  • Avus E30
    • 3650
    shouldnt this be in a technicaly forum? Sorry cant help ya.
    HDE30 <3
    • jackyl
      • Sep 2005
      • 76
      anyone?
      • Ryan Stewart
        I Love Miatas
        • 8978
        Do you have an owners manual? It lists the fuses by number. If not get a Bentley Service Manual. It has a list of the fuses and a description of each system they affect.
        Im now E30less.
        • jackyl
          • Sep 2005
          • 76
          No owners manual or bentley service manual :(
          I´ll check if the hayne´s got something.
          • jackyl
            • Sep 2005
            • 76
            Nope, nothing on the haynes manual... :(
            Can anyone scan a owners manual that shows what i need?
            Thanks
            • redbull 325is
              • 7472
              Fuse Rating Description
              1 7.5 Headlight, left high beam
              2 7.5 Headlight, right high beam
              3 15 Aux. cooling fan, low speed
              4 15 Turn signals
              emergency flasher
              Active Check control
              Digital Clock
              5 30 Windshield wiper and washer
              6 7.5 Stop lights
              Cruise control
              Active check control
              ABS
              Interior lights
              7 15 Horn
              8 30 Rear defogger
              9 15 Fuel delivery
              Idle speed
              10 7.5 Seat belt warning system
              Service interval indicator
              Tachometer/fuel economy gauge
              Instrument gauges and indicators
              Brake warning system
              Back-up lights
              OBC
              Starter
              Fuel delivery
              Idle speed
              Stop lights and cruise control
              11 7.5 Fuel pump
              12 7.5 Radio power
              Speedometer/instrument indicators
              OBC
              Multifunction Clock
              13 7.5 Left Low Beam
              14 7.5 Right Low Beam
              15 Not Used
              16 15 Heated Seats
              17 30 Sunroof
              Power Windows
              18 30 Aux. cooling fan, high speed
              19 7.5 Aux. cooling fan
              Interior lights
              Power mirrors
              20 30 Heater/Air conditioner
              Auxiliary Radiator cooling fan
              21 7.5 Glovebox light
              Flashlight
              Ignition Key/Seat Belt warning
              Interior Lights
              Radio Memory
              Trunk Light
              Active Check Control
              Service Interval Indicator
              OBC
              Fuel deliveryTachometer/Fuel Economy Gauge
              Digital Clock
              Multi Function Clock
              22 7.5 Active Check Control
              Front Parking Lights
              Taillights
              Front Side Marker Lights
              23 7.5 Instrument Panel Lights
              Taillights
              Rear Side Marker/License Plate Lights
              Rear Defogger
              Multi-Function Clock
              OBC
              24 15 Turn Signals
              Emergency Flasher
              25 Not Used
              26 Not Used
              27 30 Interior Lights
              Central Locking
              OBC
              Radio Amplifier
              28 30 Lighter
              Power Antenna
              29 7.5 Left Fog Light
              30 7.5 Right Fog Light
              stolen off BEN
              HTH
              Julien
              Build Threads:
              • jackyl
                • Sep 2005
                • 76
                Many thanks.
                After reading this, i think, and hope, that one of my problems are in fuse number 19, because the electric mirror and the interior light don&#180;t work.
                I have to check if the aux colling fan works (i think this is the interior ventilation - cabin ventilation).
