89 325is, PO said the air was cold but sat up for 6 months, the pressure is right, but compressor just comes on about every few minutes or so and only for a few seconds, i jumped the pressure switch for longer compressor run and no cold air at all. Do you think it's expansion valve?
a/c question, expansion valve??
Tags: None
There is a sticker saying its been converted to r134a, not sure of the extent of that...but I'll recheck pressures and post later.Comment
No, I think you are just slightly low on freon.
Don't refill it with one of those "recharge kits" that has 134a and oil. Borrow or buy the stuff to fill it with pure r134, and only a teeny bit should do it. Maybe 1/3 of a can.Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
Ground Control Gallery
The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
Well, seems its blowing ice cold now, i guess the pressure switch is bad, after jumping the wires to run the compressor long enough and taking it down the highway, it really started to blow cold!!Comment
Based on your last statement I would also guess your switch is bad. Is it always cold on the highway or is it completely random? If random, then replace the switch. If always cold on the highway then it is the compressor or aux fan.
The only way to be 100% certain is to check pressures.90 325i DD/Track
03 Durango 5.9
Originally posted by e30mpgIt is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.Comment
