Check panel brake light warning
    As an FYI...
    My restoration project car had an annoying habit of having the brake light warning led light up in the Check Panel (and the Flashing CHECK in the cluster) about a third of the time. I'd already replaced all the brake light bulbs with plated base Osrams, cleaned all of the bulb sockets, and the connectors. BTW: a brass bristle shotgun cleaning brush works like a champ. Get one that has little to no wire sticking out or trim it back to get deep into the sockets.
    In retrospect it should have been obvious, but I didn't figure it out for a while. The cause was the brake light switch. While it was good enough to operate the brake lights it had just enough resistance to trigger the warning led some of the time. A simple check for this is to disconnect the switch, turn on the ignition, and use a wire to simulate the switch closing. If you do that multiple times with no warning led, replace the switch.
  • 36brua
    • 689
    Thanks for the heads up. ya never know what's next with an E30 electrical system
    My CA legal M60 swap
    The happening in our garage
    • TimKninja
      • 2131
      It was actually a recall by BMW at one point, The brake light switch seized on my first E30 (85 325e). Couldn't figure out why the light wasn't going off.
      1985 325e M50TU(Sold)
      1991 318is Slicktop (Sold)
      1990 325is Brilliantrot S50/5 Lug Swapped.
      1992 525i Manual shitbox Winter Beater
      • audiquattrot
        • May 2008
        • 3836
        good to know. had this issue in all of my E30s past/present.
        www.instagram.com/snwmble
        #snwmble
        Current:
        '05 BMW M3 - Silver Grey/Imola Red
        '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
        '15 Mini Countryman - Blazing Red/Carbon Black
        Past:
        '01 Audi Allroad - Light Silver/Platinum Saber Black
        '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
        '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
        '90 BMW 325i - Schwarz/Tan sport *Sold*
        '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
        • Urnatha
          • Sep 2012
          • 5
          Originally posted by jlevie
          As an FYI...
          In retrospect it should have been obvious, but I didn't figure it out for a while. The cause was the brake light switch. While it was good enough to operate the brake led tubes it had just enough resistance to trigger the warning led some of the time. A simple check for this is to disconnect the switch, turn on the ignition, and use a wire to simulate the switch closing. If you do that multiple times with no warning led, replace the switch.
          These LED brake lights are creating problem for me. They light for some time and then gets off. What could be the reason?
            If you are talking about the brake warning LED in the Check Panel, understanding how the LED works may help.
            Each of the monitored light circuits has reed relay wrapped in a coil of wire that is a part of the circuit. If sufficient current flow exists through the coil the reed relay closes. So anything that reduces current flow though the circuit will turn on the warning LED. Possible causes include aged bulbs, corrosion in the bulb sockets/connectors, bad fuse, damaged wiring, or bad switch.
            • mcskibadee1
              • Feb 2012
              • 1379
              stupid question I'm sure but where is the brake light switch?
              TRANSACTION FEEDBACK HERE
              FOR SALE ITEMS HERE
                The brake light switch is on a bracket over the pedal arm.
                • StereoInstaller1
                  GAS
                  • 22679
                  Another common cause of this issue is corroded connectors on the check panel diode pack.
                  Personally, having completely solved the issue on well over 2 dozen cars by simply cleaning the contacts (the bulb base thing is a myth) that is the first thing I do, and generally, it cures it.
                  Luke
                  Closing SOON!
                  Thanks for 10 years of fun!
                    APersonally, having completely solved the issue on well over 2 dozen cars by simply cleaning the contacts (the bulb base thing is a myth) that is the first thing I do, and generally, it cures it.
                    I disagree because I've seen cases where all that was necessary to fix a persistent brake warning light issue was to replace the brass based bulbs (that were obviously corroded) with plated base bulbs.
                    • xcx4x
                      • Sep 2013
                      • 184
                      As an FYI...
                      How do I "disconnect the switch"?
                      Where do I stick the wire to simulate the switch closing?
                      Thanks.
                      edit: found a youtube video
                      • Aleman
                        • Mar 2012
                        • 1590
                        Seeing as how it sucks to work under the dash, I skipped the test and just replaced the brake light switch with a new genuine BMW part for $25. The part looks a little different from the original, so it's safe to say they probably improved its design at some point. Anyway, the brake light warning doesn't come on any more. Thanks, Jim, for pointing me in the right direction to look at the brake light switch.
                        R135 /// 1990 Alpinweiß II 325is
                        └┼┼┘ /// 1993 Black/Black Convertible (sold)
                        ..24
