86 325 air conditioning doesnt blow cold air
  • BMW***325
    • Aug 2012
    • 45
    i cant cold air to come out of the vents and i would like to know what i should do? Can i by refrigerant, if i can what kind , can i use 18 Oz. Arctic Freeze Refrigerant With Dispenser And Gauge? i need help
  • CW325
    • Jul 2011
    • 1434
    It will need to be recharged with r12 freon which isn't that easy to find and install. I think there's a thread in the DIY FAQ section about converting your ac to a different refrigerant if you can't find a shop with r12.
      • 37833
      Something that people often overlook is that A/C systems don't just run out of refrigerant.
      Smartest thing is to find the cause of the leak first.
      Grover Beach, California
      BimmerHeads.com
      • NV325i
        • May 2012
        • 236
        You can charge it with Freeze 12, its meant to mix with r12.
        http://www.amazon.com/Freeze-12-Refr...ords=freeze+12
        Current: '92 325i Vert
        Past: '84 Euro 320i -Had to leave in Italy
        • poopin04
          • Jul 2010
          • 1396
          I actually bought this stuff last year and it actually worked. Wasn't as good as R12 but did the job, until it all leaked out. :( My suggestion is if you can find R12 keep your system in place, that stuff will make sure sweat turn to ice. BUt if you have leaks in your system, don't waste your time just swap out the system I say.
          Click here to leave me feedback on our transactions. :p
