Ignition switch install
  • tonstermits
    • Apr 2012
    • 3
    Over the weekend I did a dashboard swap and in the process broke my ignition switch. My car is sitting at my dads house and he offered to install the ignition switch a couple days ago, unfortunately he did the install with the battery hooked up. I have yet to go and check it out but he is saying the car will not start. What kind of damage should I expect or look for to solve this issue?
    Thanks guys
    If done correctly, it should not matter if the ignition switch was changed with the battery connected. Does the engine crank? Is there spark when cranking?
