Cabrio soft top leak
  • Ceeker
    • Sep 2009
    • 2821
    Hope this isn't in the wrong section:
    problem: installed a fairly new soft top with frame onto my cabrio. I basically lined up the roof with the shims and checked alignment of windows etc. I did a hose down test for leaks and found water comes in from around the center front seal. The seal is fairly new as well. Can anyone suggest what I might have missed while putting the roof on.
    any help would be appreciated.
    thx.
  • dnguyen1963
    • Nov 2011
    • 2649
    Try this...
    • dnguyen1963
      • Nov 2011
      • 2649
      Try this...
      • Ceeker
        • Sep 2009
        • 2821
        Originally posted by dnguyen1963
        ok, so clearly now I see the problem. When I was mounting the roof I noticed the rubber seal came away from the front of the frame rail. clearly it wasn't glued in like it was suppose to be. So.... I guess I'll be doing this sometime today or tomorrow. thanks for the link. I have seen it before but thought it was just for worn seals.
        much appreciated and Happy Labor day weekend.
        • Ceeker
          • Sep 2009
          • 2821
          well after cleaning and applying the sealer; I have no luck. there is gaping on the drivers front between the window and the seal but the passenger side is tight. However, when I soak the roof water is getting in on the passenger side. I wonder if I ad a shim to the rear bottom will it pitch to roof forward to give me a better seal? or do I remove a shim so that the front takes more down force to close the latch?
          • smooth
            • Apr 2005
            • 1940
            What did you find out regarding shims?
            Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
