Mystery Connector - Help!
  • sharkd
    • Apr 2005
    • 82
    I found a mystery connector/loop and I have no idea where it's from or what it does... It's a plastic friction connector with a pair of spade terminals and a single green/red wire looped between them.
    I had the fabricator finish the cage install over Thanksgiving, so the dash and instrument panel were out for a while. After getting the car back, last friday, I cleaned up the wiring behind the dash -- disconnecting the sunroof wiring harness, the original radio harness and relocated the check panel wiring to the sunglasses holder.
    Then, on Sunday, when I got into the car to drive from NC back to DC, I found this connector in the drivers' footwell. Everything seems to work fine, the car ran, the radio works and the instrument panel lights up. I really don't want to wrestle with the dash again, so can anyone tell me what this is and if it's important?
    The car is an 03/87 production 1987 325iS.
    Thanks.
    “one of the most beautiful BMW’s ever...”
  • rs4pro3
    • 5808
    loop to make the cruise control work on automatic cars, plugs in where the clutch switch would on a manual car.
    85 325e 2.7 ITB'd stroker
    • e30Matt
      • 5077
      Curious, who did the install on your cage? Korman or Motorsport Connections by chance?
      Oh, and +1 to Ely.
      • jht3
        • 288
        i'd be shocked if his car were an automatic. why would anyone race an auto?
        James
        '88 M3
        • sharkd
          • Apr 2005
          • 82
          Well, that would explain why the clutch switch has never seemed to work -- if the car never had one to begin with... (It was built as a 5 speed, but the previous owner was cheap, so he might have replaced a faulty clutch switch with a loop from an automatic.) BTW, Cruise control did work on Sunday...
          The cage was fabbed by Chris Schimmel in Hillsborough, NC (www.CompetitionCages.com). I'm very happy with his work.
