EWS III (3) delete or bypass?
  • kevinbednarek
    • May 2012
    • 35
    So here's the deal. I was rocking along with my M62 swap and now I'm at the wiring portion. I started with a 97 540i with a 6 speed manual I found for a donor car. I had everything I needed to finish, the EWS module, DME, antenna, key and everything. I live in what I thought was a pretty good area, and I had a gutted car just parked outside my house. Being that no one could drive it away, I left my only key in the car.. So I come home one day and my e39 is gone. Kind of a bummer I thought at first (it wasn't much use because I got the good parts out of it. Then it hits me, the key is in the car and I have no way of getting another one!
    So my question is this, is there a way to bypass an EWS 3 system or am I screwed? I have been researching this for a while and I guess there may be some way to bypass an EWS 2 system with some cutting and joining of wires. Is there a way to do this with the more current system? Otherwise I have been told I am posed with two other options. One, reflash the ECU to delete the EWS system. Two, convert to an OBD 1 setup with a very early 90s (pre EWS) M60 wiring setup with a new wiring harness and ECU.
    Does anyone know which option would be best? I think the delete or convert options may get spendy. Has anyone had this problem before?
    Thanks for the help.
    I believe the DME can be reprogrammed to delete EWS. Talk to a race shop, like Bimmerworld or Turner
    • CarsSuck
      • Oct 2005
      • 968
      does your town have an ordinance against parking heaps of shit on the side of the road? Maybe you should check the impound lot and maybe get your key back. I mean, you have to be pretty fucking stupid to steal a stripped car....
      --Will
