My ABS relay light came on a while back. I picked up a new relay and finally got around to replacing it yesterday. My problem... i can't find the damn relay to replace it. I have the lower bolster removed. I also took out the ABS controller, pulled wiring out of the way, removed the lower cover of the steering column... nothing. I even started looking behind the climate controls, above/behind the glove box, and in the engine bay.
I know my ABS worked before as I was testing it out on a rainy day this past spring.
The only thing I found was a bundle of five wires that were cut and taped. Can someone tell me what the color the wires are that go to the ABS relay? I'm not sure how my ABS worked without the relay, maybe it's hard wired (bypassed relay)... if it would even work that way.
