How to repair a dash crack?
  • 86325e
    • 228
    I HAD a prestine dash board. I was going to install it today and noticed a small crack that is 1/2 inch long up in front of the defrost vents where it will mate up against the windshield. I picked up one of those Permatex Dash repair kits but don't know if I should use it. I wanted to get some input first. Some people mention drilling holes to relieve stress, others just say fill it with epoxy, others say use the dash repair kit. Who has done what and are they happy with the results?
    Eric
    85 325e M50 and auto to manual transmission conversion...
  • AndrewBird
    The Mad Scientist
    • 11897
    There isn't much you can do. If it's a small crack, I would drill a hole at each end to keep the crack from becoming bigger and then forget that it is there.
    • 86325e
      • 228
      Drilled a hole to stop it and filled it with some silicone adhesive/filler. I should be done with it tonight.
      Eric
      • DarkWing6
        • Apr 2004
        • 7144
        post pics when done
        • Mot
          45 toting redneck
          • 4018
          I just found a new mint dash for 25 bucks at the junkyard. But im an asshole who finds deals like that.
