Shudder under acceleration
  • Aytah
    • Dec 2005
    • 69
    Just wondering what could be the cause of the following problem:
    Under moderate to hard acceleration there is a sort of shudder coming from the rear once I pass 3000 rpm then it goes away. I'm assuming the problem is somewhere between the tranny and diff, but it definitely feels like its coming from the rear of the car. The only known issue is that one of my rear winter tires is mounted backwards (which I'm getting fixed this week-end). Could it be the gears in the diff are wearing out (car has 320000 kms on it), or possibly a driveshaft/guibo problem?
    Any suggestions are appreciated.
    Jager + Red Bull = Enhanced ladying abilities
  • 88325isboy
    • Mar 2004
    • 1058
    driveshaft.
    '87 325 (Track Rat)
    '04 C5500 Wrecker (Work)
    '94 525i (Daily)
    '90 325i (R.I.P)
    H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
    • I_like_E30
      • Oct 2004
      • 87
      could it be a loose rear-end?
      • Rob
        • 8166
        could you be more specific?
        BEERTECH
        • Aytah
          • Dec 2005
          • 69
          I'm pretty sure its a rotating part since it gets worse the harder I push it. Can the insides of a differential become loose? Maybe a Diff fluid change would help. I just bought the car, but I know that it had a new Diff put in a year ago, thats why I don't think its that.
          When they have it on the lift to fix the tire I'll have a look at the driveshaft and diff. I know I should be looking for anything loose, but is there anything else I should inspect?
          • 88325isboy
            • Mar 2004
            • 1058
            I would have them see how much play is in the driveshaft itself and check the guibo to make sure it is not broken and the center support bearing also.
            '87 325 (Track Rat)
            '94 525i (Daily)
            '90 325i (R.I.P)
            • NC325iC
              • Mar 2004
              • 6565
              all your guibo bolts in?
              • Joe318is
                • Sep 2005
                • 6451
                Center Bearing!!!! Omg?!?!?!?
                Originally posted by vlad
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Center support bearing or an unbalanced driveshaft. Some times the weights used to balance the driveshaft will fall off making it unbalanced and then it will rip your center support bearing and flex disk apart. Bad part is you have to drop a bunch of heat shields to even see.
