Clutch, Oil Pan Gasket, Timing Belt, etc. - Remove Engine or Not?
  • Timp
    • Jun 2011
    • 126
    Long post, I know! Read the tl;dr below for a summary.
    Lately I've been able to do a bit more work on my car and as someone who is learning a whole lot in the process (no previous mechanical experience at all), it has been very gratifying. I've done the following myself since I got my '87 325E a year ago:
    190K - Replaced fuel pump and filter
    197K - Valve adjustment
    198200 - Front brakes and rotors.
    198250 - Tranny and diff fluid.
    199000 - Replaced spark plugs. Replaced air filter.
    199100 - Replaced O2 sensor.
    199800 - Replaced both rear bearings, parking brake shoes, rotors and pads.
    Here are the issues I'm facing now:
    Clutch: There isn't much left on this. This is fairly important to get replaced in the near future. Also need to replace shifter bushings.
    Oil Pan Gasket: My car sat for two and a half weeks recently, and it left quite a large puddle of oil in the driveway. I knew from the beginning that this was leaking but the replacement procedure sounds fairly difficult.
    Timing Belt/Water Pump: Timing belt was supposedly replaced at 170K and my car is at 200K. I do live in a dry climate however, and often my car will sit for awhile. Though lately I've been using it for around town driving (unfortunately my commutes are short lately, and not long enough for the engine to warm up fully).
    So those are the upcoming maintenance items. Here's other issues I'm not quite sure how to tackle:
    Poor Fuel Economy: I get about ~22 in the city with conservative driving. Really though - I am accelerating slowly, I wonder if this has to do with a potentially bad valve adjustment on my part. How can you tell if a valve adjustment is not good?
    Engine Temp: When highway driving in summer, especially going up hills, the gauge has on a few occasions hit nearly the red zone. Also while idling, the gauge has a tendency to read high. I have not bled the cooling system yet, but the fan clutch appears to be strong.
    Vibrations: When in 2nd gear from 2-2.5K, and 3rd gear from 1.5-2K, it feels like the engine or the drivetrain (I can't tell, feels like the whole car) shakes. Hot or cold - doesn't matter. One thing to note, after I replaced my rear bearings, I jacked up the rear and ran the car in 5th gear. The rear end seemed to make a sort of a grinding noise. I don't notice any excessive noise back there when I'm driving. Should the differential run quietly when jacked up?
    The car also shakes when idling on occasion. As for the motor mounts - when I apply throttle, the engine does move about an inch or a bit more when I'm looking at it.
    So that's what I'm dealing with. Unfortunately I don't have access to a garage, but I can keep my car covered and have a reasonable space to work.
    My question is: Should I just pull out the engine and get the oil pan gasket, clutch, and timing belt done? I'm assuming these jobs are easier to do with the engine out. However - just reading the process of everything involved and looking at videos like these makes the process look very involved and intimidating.
    So, for you guys who have plenty of experience, how would you recommend I handle all of these issues? Leave the engine in? Or take it out (with tranny), put it on a stand and work on all of these things? I'm sorry for being vague in my presentation of all these issues - I just want to know what you guys would do if you were in my shoes.
    Thanks for reading everyone. Sorry for the length.
    Obligatory picture of my baby:
    tl;dr - Clutch, oil pan gasket, and the timing belt/water pump should be replaced. I also have other issues like poor fuel economy, engine temp issues, and vibrations under acceleration. Should I take out the engine/tranny, fix those issues above among other projects, or just leave it in? I have very little mechanical experience.
    Newb to all the things.
  • markt51
    • Apr 2012
    • 329
    Timing belt and water pump are fairly easy. Its just a lot of easy work. I think it took me about 4 hours with car slightly jacked up. I took the hood off, removed the radiator, and put all the nuts and bolts into labeled ziplock bags to make it easier. Again its not very difficult, its just time consuming work. Google "e30 water pump replacement" and there are alot of pretty detailed diy articles.
    89 325i Coupe Auto Delphin Metallic - Sold
    91 325i Sedan Auto Brilliantrot - Sold
    83 323i Euro Coupe Manual Lapisblue - Sold
    89 325i Coupe Manual Delphin - Sold
    89 325i Sedan Auto Brilliantrot
    87 325i Vert Manual Brilliantrot
    • pantelones
      • May 2011
      • 533
      ^^^ Your post is useless.....
      In short, if you have to replace the clutch, and do the oil pan then I would suggest pulling the motor. You don't have to use the cherry picker, I dropped mine out through the bottom since I was doing a front end refresh and manual swap. About 4 hours prep, and 2 hours to get it out. It wasn't that bad, and it was my first time pulling the motor. Just label anything you are unsure of, but for the most part everything falls back into place if you take your time disassembling it and making good mental notes/connections. Keep it organized, it really helps when you put it back together.
      IMG_3893 by Los Pantelones!, on Flickr
      A man chooses, a slave obeys... Would you kindly?
        • 37832
        Honestly, I'd pull it out and give the whole thing a GOOD cleaning and refresh along with your list of parts.
        I don't drop engines out the bottom like pictured above though. ;)
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Timp
          • Jun 2011
          • 126
          Thanks for the responses so far guys!
          It does seem pretty appealing to get the engine out and clean up that bay and all the parts really good. Would doing the clutch outside of the engine be feasible on an engine stand? I am completely new to all of this and don't know how balanced this would be. I can rent an engine hoist from a parts store around here and engine stands can be had pretty cheap used.
          Does anyone have any input on how I can check to see how effective my valve job was? Would a leakdown or compression test reveal anything?
          Also, about the drivetrain - any input on there would be hugely appreciated. Is a slight whirring/whining noise that increases in pitch from the back normal in 1st gear up to 10 mph?
          • Timp
            • Jun 2011
            • 126
            Bump. I could really use some pointers on whether or not there is a way to test whether or not the valves are being adjusted as best as they can.
            • Rose E30
              • Jun 2012
              • 113
              Listen to hear if they are clicking. Also try to slip the next size feeler gauge between the rocker and valve. If you cannot, then they are tightly adjusted.
              Zinno 87 325iS
              • mrgraphics
                • 221
                So is clicking good? Mine has a significant slow "tick tick tick tick" at idle. As I accelerate the ticking gets faster obviously. I've adjusted my valves twice out of paranoia.
                • Herr Faust Schinken
                  • Feb 2012
                  • 3580
                  Ticking isn't bad it's clacking most m20 sound like sewing machines even if your valves are ajusted correctly but clacking means that they are way to loose or something else is wrong
                  Op I'd just pull the engine everything is easyer to do with. THe engine out the engine bay change all your v belts while you have the motor out too
                  88 325is Five Speed
                  Lachssilber
                  • Timp
                    • Jun 2011
                    • 126
                    Same concern here. Even with a particular feeler gauge, you can make the clearances tight or loose. The first valve adjustment for me was a bit confusing because I never knew how loose or tight it should have been. But, from what I understand, an M20 that sounds like a sewing machine is normal.
                    I just wish there were a better way to find out if I did the job right. If I'm over thinking this, someone let me know.
