What's going on in this spark plug hole?
  • cferb
    • 1442
    Pulled out my spark plugs and there was a flaky white film around it, as well as in the spark plug hole
    What can you tell me from that pic? Seems odd to me since it's outside of the hole. Doesn't look to pretty inside it either but that might be the flash or something.
    Car is an '88 M3 if it makes a difference. The spark plug gaskets are/were leaking, maybe something related? Seems to run okay, but it's a project so it's kind of difficult to judge.
    TIA :up:
  • dnguyen1963
    • Nov 2011
    • 2648
    My guess is aluminum oxide. A small leak of electrical charge from the spark plug can lead to the oxidation of the aluminum to give you that white flakes. Or just the dust from the heat shield.
    • cferb
      • 1442
      Hmm, so what can I do about that? That would make sense, PO didn't have the screw on caps on the spark plugs :?
      And how do I go about cleaning that hole out?
      • AndrewBird
        The Mad Scientist
        • 11898
        Almost looks like the previous owner siliconed the spark plus in. The white is the silicone left behind. Would explain why they were leaking.
        • dnguyen1963
          • Nov 2011
          • 2648
          Put the spark plug back in then use compressed air to blow it out.
          • cferb
            • 1442
            Sweet I'll try it out, thanks
            I don't think the PO was that Bad to the car, i doubt and hope it wasnt siliconed in.
            • Aldrich
              • Oct 2012
              • 5
              HI all,According to me aluminium oxide is spark your plug A small leak of electrical charge from the spark plug can lead to the oxidation of the aluminum to give you that white flakes. Or just the dust from the heat shield.
              4x4 lift kits
              • motorking
                • Oct 2012
                • 1
                plug residue
                TIA :up:
                Good morning
                I am the technical manager at Autolite Spark plugs. It looks as though the previous owner may have used silicone grease on the threads of the plugs. Use a shop vac and clean all that out as good as you can. Is is VITAL that spark plugs be properly torqued and tight. Outside of firing the fuel mixture, a spark plug must transfer heat from the plug tip to the cylinder head and cooling system. Without this heat transfer, you can have the car go into what is called pre-ignition and it will/could actually destroy the engine. There is a good explanation of this in this video
                • cferb
                  • 1442
                  No way man that's just crazy talk
                  Originally posted by motorking
                  Good morning
                  http://www.youtube.com/watch?v=U90PMvy3PAY
                  Not sure if bot...
                  But the white you're looking at is outside of the threads, the threads are deeper In that smaller circle past all the cracked stuff. Also this is only on one plug, so i doubt if the PO put anything on the threads.
