Instrument Cluster Lights
  • e30partsguy
    • Oct 2012
    • 173
    Stephen, you should move the 'arrow light' two spots to the left to use as the fog light. CEL uses the light bulb that attached with the white connector, the one you have to pull out when you want to take cluster out. You have to pull out two light bulbs when you take cluster out, the one on the left (white connector) is for CEL and the one on the right (blue connector) is for anti-lock brake.
