E30 floor pans??
  • involution
    • Oct 2012
    • 10
    E30 floor pans??
    Hey guys I discovered quite a bit of rust in both front floor pans and was wondering where I could find replacement pans. I've been looking around but haven't found anything, I've even been searching for a fairly clean e30 to cut up.. Any help?
  • spike68
    • Apr 2009
    • 1185
    cut out. weld in some sheet metal. Done.
    that shouldnt take a thread.
    I don't even own this car anymore, but I'm too lazy to change the picture.
    • AndrewBird
      The Mad Scientist
      • 11898
      I believe he is looking for replacement pans, not some ass hat telling him "cut weld done". :roll:
      OP, I am unaware of anywhere that sells floor pans. RealOEM.com doesn't even show the floor pans that I can find. So you will either need to find a clean donor shell or fabricate your own panels.
      • spike68
        • Apr 2009
        • 1185
        I is ass hat :)
        To be serious, I agree with you. You pretty much have to find a donor or fabricate.
        OP: For some reason, I never dealt with this problem. I think the previous owner (back in 90) re-coated the underside of the car as if he knew it was going to rust over. The car was originally in the north (Chicago), so its a pretty common issue. I guess i got lucky :up:
        • involution
          • Oct 2012
          • 10
          Yeah thats what I've figured, spent the last couple days trying to find replacements but nothing, got some sheet metal lying around so i'll probably ended up welding some together.
          I got pretty unlucky, all the frame is good same with the body but the previous owner had it sitting outside with a leaky sunroof so my floors got ruined... I hate rust...
          • KillaCam
            • 2103
            junkyard!
            Originally posted by E30_(1st Musk)_
            HONDA IS WHERE EVERY TREND DIES! .
            24v swap Oil Pan..F/S
