Brake lining light is on????
  • amcink
    • 788
    I have install two new brake pad sensor on but my light in the cluster still on. What should i look for?
  • Maddog
    • Dec 2006
    • 117
    You could have a break on your instrument cluster board that will cause the light to stay on.
    This was the cause of my lights being on; fortunately, I had a spare instrument cluster to check it.
    • amcink
      • 788
      I have a spare and will try to compare thanks
      • dnguyen1963
        • Nov 2011
        • 2651
        Mine and many others here have the light on forever...just ignore it or pop the cluster out and remove the bulb.
        • dogsbark26
          • Nov 2008
          • 533
          Soldering the resistor on the cluster circuit board fixed mine. Read this.
          • mbonanni
            • Sep 2011
            • 6236
            Make sure you installed new sensors correctly
            • bowtie2bimmer
              • 830
              Or the connection to the sensor is corroded and needs to be cleaned
              1987 BMW 325ic - Emma
              • Ceeker
                • Sep 2009
                • 2821
                As mentioned - make sure the contact pins inside are not corroded. clean with contact cleaner and some sand paper. then put some dialectical grease on the pins to create a better contact and to prevent further corrosion.
                • Simon S
                  • Oct 2004
                  • 3758
                  I had the light come on intermittently after doing a full brake job with new sensors..
                  fwiw - it took me a while to trace the fault to the connection plug at the right/rear wheel. Basically - the female connection on one side of the plug was too tight and simply pushed the male connection back into its plug housing. After some fiddling around with needlenose pliers, I got the female connection sized right and now enjoy functioning wear sensors with no dash light on..
                  -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
