coolant lead
  • NC325iC
    • Mar 2004
    • 6565
    coolant lead
    alright give me some common places, i dont think its comin from the head gasket, i realllllly hope it isnt. and i dont think its a hose ive been over them alot.
    could it be a lose water pump? or bad seal there?
    just give me ideas of where to look
    thanks
  • JeffG
    • Jan 2005
    • 135
    i'd recommend pressure testing your system an examining the cooling system from there. look at hoses, water pump, your throttle body gasket and anywhere else for any signs of residue, seepage, or dripping. check your oil as well if you're concerned about headgasket issues. make sure your radiator cap can hold pressure as well.
    if you don't have a pressure tester i'd recommend picking one up with an adapter to fit the expansion tank, it's a very valuable tool and it's accurate diagnosis. other than that you'll just be guessing...
    hope this helps some.
    • NC325iC
      • Mar 2004
      • 6565
      thanks for the idea, yeah ive checked the oil and changed it since the leak has started and it looks normal. ill go look inot the pressure tester
