guys i have discovered a huge and I mean BIG leak into my driver floor board. its not the heater coar, it due to the rain and im guessing its coming from the exterior in because the car has been siting for a week and my driver floor is like flooded. anyone have/had this proble or any clues at to what it can be?were to start troubleshooting? ANYTHING would be helpful. i cant believe it, but its something thats gonna heve to get fixed ASAP. thanks
Leaking Help
I would bet that the jack point is rusted out, or under the fuse box in the engine comp. is rusted out. if not those 2 spots, its probably under the splash shield in the front wheelwell. to check it out, peel the carpet back, and take a look at th3e mess that is there! seen a ton of them. I am one of the few welders for the after bamberg inspection failing-- when the BMWs fail for rust. they are really hard on rust here for the army inspections.
1) Sunroof drain is clogged, and your flooding through the speaker hole in the footwell
2) Splash shield, as Mike mentioned.
3) Under fuse box, as Mike mentioned
4) Cowel, behind/below the wiper covers/air vents. Rusted out. BTDT.
I'm wagering on 1, 3, or 4. Since it occured when the car was sitting, and not driving.Below the radar...
Originally posted by UNHCLL1) Sunroof drain is clogged, and your flooding through the speaker hole in the footwell
Hope that's helpful.
