fuel pump removal
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    fuel pump removal
    On an '88 325iS, can it be replaced by removing the the rear seat and accessing it from there, or does the tank have to come out? thanks.
    Darin
  • kowalski
    • Jan 2005
    • 1791
    depends on which pump yout alking about, but the one in the tank is do-able by removing the seat.
    • CorvallisBMW
      • 13039
      Is there more than one pump?
      • lordofthewaters
        • Oct 2005
        • 714
        fuel pump
        The older E30's I think 87 back (I'm not positive) had 2 a transfer pump in the tank and another that I guess you'd call an "in line" pump behind the tank in front of the rear wheel. I have and 89 325i and no sign of any "in line pump".
        Just pop my back seat out unscrew a few nuts, and lift it out.
        Sarcasm is a body's natural defense against stupid.
        When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
        "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
        Old age and treachery will always overcome youth and skill.
        • lordofthewaters
          • Oct 2005
          • 714
          not nuts but screws.
          • AdamF 88iS
            • 2051
            1988 and up only have a single intake pump. You can remove it in the car from under the seat.
            87 and down have dual pumps.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • DarkWing6
              • Apr 2004
              • 7144
              1) Pop out rear seat
              2) Pull back padding/cover
              3) Take out 4 screws holding the cover (cover is black thing on pass side)
              4) Pull off lines (be careful, some gas may be in the lines)
              5) Twist pump to remove
              6) Pull out pump carefully
              To put back in do steps in reverse.
              • kowalski
                • Jan 2005
                • 1791
                they are nuts... there is 4 of them. on the tank
                4 screws to remove the hatch.
                • platanos
                  • Apr 2008
                  • 459
                  I have a 1990 ic. When I twist the pump and lift up, I can only get about an inch out of it. It seems to get stuck. I tried wiggling the shit out of it in every direction. Still won't come out.
                  ~Fernando
                  • E30SPDFRK
                    • 5695
                    You need to remove the fuel sender first, then the pump assemble twists out.
                    Byron
                    Leichtbau
                    • platanos
                      • Apr 2008
                      • 459
                      So how do I remove the sender?
                      ~Fernando
                      • Jean
                        • 18228
                        ?? look at it, remove four nuts that hold it to the fuel pump assembly.
