Hood won't close *RAGE*
  • Mr. Burns
    • Aug 2011
    • 3516
    my hood latch will no longer engage and catch.
    slamming the hood down doesn't help.
    I'd sprayed the latch with wd-40/younameit and nothing make it want to operate normally any more.
    how have you repaired this issue?
    new cable/latch?
    just latch?
    such a PITA.
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • Desaevious
    • Aug 2007
    • 3810
    This is happening to me RIGHT NOW. With 50mph winds coming. RIGHT NOW. Fuck you E30, only at the worst time do you pull this shit on me.
    SC*AR (Schwarz Army)
    • Mr. Burns
      • Aug 2011
      • 3516
      pretty much same thing happened to me.
      cruising at 50-60mph on highway, calm weather, sunny day.
      *BOOM* the whole hood lifts up, thank god it opens reverse style...scared the hell outta me.
      simply gave up I guess?
      • ttrousdell
        • Nov 2009
        • 1770
        if you take a large screwdriver and push it down can you get it to click/lock. It if moves free and doesnt lock when pushed all the way down the latch is probably worn out.
        The Build:
        • Exodus_2pt0
          • 5943
          If it gave out while driving, replace the latch. If it just wouldn't close after opening it, then I would say try to repair.
          No E30 Club
          • E30Gus
            • Jun 2008
            • 781
            I had this happen on the highway. I took the latch out and cleaned it the best I could then lubed it. This should fix it unless parts are bent somehow.
            • AndrewBird
              The Mad Scientist
              • 11898
              Make sure the release handle inside the car is returning back all the way. If it is stuck pulled a bit, the hood won't latch.
              • defaultName
                • Jul 2010
                • 859
                Most likely only the latch needs to be replaced and not the cable.
                My hood wouldn't latch down so I bought a new latch and cable because I wan't sure what it was.
                It's quick and easy to replace (and cheap) and I would recommend not trying to fix it. I tried to fix mine while I waited for the latch to arrive and it didn't work.
                Buy and sell your E30s and E30 parts on E30 Marketplace!
