As the topic said, i need a puller electric fan to replace the stock fan clutch set up. Which one you recommend? I think it will be a 16" and over 2000cfm will be enough? what u think of this one? http://www.ebay.com/itm/Zirgo-Ultra-...&forceRpt=true Is it crap?
Electric Fans (puller) which one you recommend?
I was thinking about this one too, good cfm for the pricehttp://www.summitracing.com/parts/hf...6/media/images6psi 224hp/260tq
I got one from Amazon for $30 and it works swimmingly on my M3.1974.5 Jensen Healey : 2003 330i/5Comment
Personally I use SPAL fans as I think they are built better and should last longer.
But whatever you use, resist the urge to mount the fan by anything that touches the radiator fin tubes. Through the radiator type mounts can wear a hole in a fin tube.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Why? The engine driven fan is a simple and reliable means of cooling the engine. I'll replace the fan with an electric on a race car because every last bit of power matters there. But on a street car it makes more sense to retain the fan.The car makes it possible, but the driver makes it happen.
Only reason I put an electric one is because when my radiator blew I put in a 3 row Z3 M radiator.1974.5 Jensen Healey : 2003 330i/5Comment
