Heater blows hot only at higher rpm
  • sepehr
    • Oct 2005
    • 57
    I tried changing the thermostat, but that didnt change anything.
    Is my heater core clogged? Can it be cleared with a garden hose?
    Thanks
  • PeaveyBassist
    • Sep 2004
    • 3511
    Try bleeding the cooling system. I had a similar problem. Only had heat when not at idle and with the fan speed on at least 2. I drained the radiator and block and changed the thermostat. Put new coolant in and bleed it. Fixed the problem.
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • AdamF 88iS
      • 2051
      You have an air bubble. You need to bleed it.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • 325ise30
        • May 2005
        • 61
        I think he means the blower motor only works on high, in that case it would be the blower resister.
        Previous cars, bmw's 85 325e 93 318is
        88 suzuki samurai
        • Dave
          E30 RAT
          • 11675
          My vote is that you have an air bubble.
          And BTW, I thought Heater discussions were forbidden now? ;-)
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • sepehr
            • Oct 2005
            • 57
            I bled the system from the top of the radiator. Is there any other bleed valves I'm missing? The coolant looked like it had no bubbles when it was coming out of the valve. Are there any tricks in bleeding the system?
            I had a reputable shop in here in town (Nixon Automotive) take a look at it. I got them to look at it, and give it a flush.
            They say the bottom of the radiator stays cool. What does this mean?
            Thanks for the input. I really need to get the damn thing working, moving to Regina Saskatechewan next month!
            • PeaveyBassist
              • Sep 2004
              • 3511
              What car is this??? AFAIK The only spot to bleed a 325 (m20) e30 is at the thermostat housing with the 8mm bolt on top.
              Will
              DaveCN = Old Man
              • sepehr
                • Oct 2005
                • 57
                Its a 91 318is
                • bebes2k
                  • May 2004
                  • 37
                  You need to get a new car sepehr, it's not worth fixing the heater.
