Dielectric grease in relay socket?
  • dnguyen1963
    • Nov 2011
    • 2648
    Is there any reason NOT to put dielectric grease in a relay socket? My brake light relay always acts up when it rains a lot (my vert top is not leaking, but the humidity inside is very high).
  • Sindako
    • Nov 2012
    • 116
    I won't Recomend Any Grease , But I'd Say Use An Electrical Spray .
    And Before Spraying anything make sure the battery is Unplugged .
    Also Don't Just Spray Over The Relay Box ,
    Remove The Fog Light Relay and The Low Beam Relay . Then You'll Find Two Screws One Under Those Relays and The Other on Is On The un-Loaded relay .
    Un-screw Them > Leave it Open in the Sun For a couple of hours to Let The humidity Break Free , and Then Spray The Electrical Spray Inside .and Put back on .
    • Bmjpv
      • Mar 2007
      • 561
      grease
      Yes use dielectic grease in this location.
      • FLG
        • Sep 2011
        • 3165
        No issues. I use dielectric grease on just about everything.
        Sent from my Galaxy Nexus using Tapatalk 2
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • dnguyen1963
          • Nov 2011
          • 2648
          Thanks guys.
