Cruise control routing
  • bastianshaw
    • Jan 2007
    • 2210
    So I'm hoping my CC Somehow came unplugged; from the control unit over the ecu where is the next connection/ plug?
  • Cosmic Serpent
    • Mar 2012
    • 154
    next connection is the clutch and break switches if either one of these isn't working then no cc (this probably the problem), then their is the connection to the stalk and the cc in the engine bay(should be a plug on the inside of firewall).
    • bastianshaw
      • Jan 2007
      • 2210
      Fml I have replaced both clutch and brake switched anyone got a pic of the firewall plug?
      • Cosmic Serpent
        • Mar 2012
        • 154
        • Cosmic Serpent
          • Mar 2012
          • 154
          when did it stop working?
          if the break switch or clutch switch are not suppressed properly then no cc.
          • bastianshaw
            • Jan 2007
            • 2210
            Along time ago but it did used to work
            Suppressed? You mean depressed? Properly? I thought it was kinda light switch deal ie on or off
            • Cosmic Serpent
              • Mar 2012
              • 154
              yeah sorry,
              the break/clutch peddle depresses the switch completing the circuit when there is no pressure on either, if either of these are not depressed the cc will not work. As for being like a light switch they are pressure switches but still only have an on and off position. In my experience if the switch is not in the right position (moved slightly off track of the break/clutch peddle) the switch will not be depressed properly.
              Is you car an auto if so and your break lights are working then this is not your problem as it should use the same switch.
              Also if you have removed your gauge cluster their is a wire that needs to be connected to the back, every time I remove my cluster I almost forget to connect it.
              • bastianshaw
                • Jan 2007
                • 2210
                Yea the wire that goes into the coding plug. It's in I checked that.
                • dashboardmonkey
                  FUCK YOUR WAFFLES
                  • Jun 2008
                  • 6158
                  The wire behind cluster is for speed sense, it gets its signal from the speedometer. The brake and clutch switches must BOTH be depressed in order for cc to work. When they are depressed, meaning BOTH pedals are fully returned, the curcuit IS broken, not completed.
                  -Andy
