Fan hits radiator after motor and tranny mounts replaced
  • Kevinl
    • Oct 2012
    • 897
    Last week the fan tore a hole in the radiator and I looked at why and both of the motor mounts were broken so I replaced them and the tranny mounts and it is still hitting the radiator I don't know whats going on the fan doesnt wobble it hits the radiator even just turning it by hand the radiator is a new Nissens radiator
    any ideas
    1989 BMW 325is Lachsilber metallic 5 speed
    2007 BMW 335i KARMESINROT 6 Speed manual
    2011 BMW X5 35I
  • craiggroves91
    • Oct 2009
    • 3024
    Pictures would be helpful.
    The fan is probably tweaked, maybe remove it and make sure its not bent up.
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
    • Exodus_2pt0
      • 5943
      How's the fan clutch?
      Another option is to ditch the mechanical fan. I left it out when I installed the new engine last year, been through a few 90+* days since then without issue. The condenser fan does the job fine.
      No E30 Club
      • craiggroves91
        • Oct 2009
        • 3024
        DO NOT DO THIS unless you know for sure your aux fan works or you wire up an aftermarket electric fan.
        1989 BMW 325i SOLD
          The fan hitting the radiator with new engine/transmission mounts sounds to me like a bad fan clutch an/o bad water pump.
          • Kevinl
            • Oct 2012
            • 897
            Well I took the radiator back out and I think something is wrong with the lower mounts they look like the have been welded on by somebody who wasnt a very good welder Im not sure what the story is with this.
            But I was able to get it going I just needed to keep the bottom of the radiator from sliding toward the engine.
            I didn't take any pics since I was so pissed off after taking the radiator in and out a dozen times
            I need to look at another e30 maybe at the junk yard to find out what is going on with mine and what needs to be done to make it right
            2011 BMW X5 35I
            • craiggroves91
              • Oct 2009
              • 3024
              Does it still have the plastic cup mounts that the radiator sits in?
              1989 BMW 325i SOLD
              • Kevinl
                • Oct 2012
                • 897
                it had one and I tried to see how it fit on either side and there is an issue with how it sits on the drivers side
                do they just sit on the metal part of the mounts or is it supposed to clip in or something
                2011 BMW X5 35I
                • Exodus_2pt0
                  • 5943
                  I've got a car at the shop with the head off and radiator out now. I'll take some photos tomorrow if I get the chance, for you to compare. I am curious to see what you are up against though.
                  No E30 Club
